Types of jobs with CCNA cert.
Jun 30th, 2008
What types of jobs can I apply for having a CCNA cert?
solpandor Wed, 07/02/2008 - 01:05
it all depends on the level of experience you have. If you haveno experience, then it will be hard but not impossible to get a network engineer job, so your best bet will be to get into a helpdesk role (1st line) then work you way up that way. If you posses server/admin experience or 2ndline then you will be in a good position to apply for network engineer jobs. hope this helps. pls rate if useful.
