Problems connecting to some RME sites
Joe Clarke Mon, 06/30/2008 - 12:46
What is happening on the server when this problem occurs? Is there a lot of CPU usage or disk activity? What does the pdshow output look like when this occurs?
Martin Ermel Tue, 07/01/2008 - 01:11
Also which version of LMS and RME do you have?
Are you connecting to LMS from a Client PC or the Server itself?
Which browser do you use?
Joe Clarke Tue, 07/01/2008 - 08:44
The problem may be a memory leak in Tomcat, or it could be a server CPU problem. We have at least one known bug in LMS 3.0 where the GGSCript.exe process takes up 100% of the CPU.
Joe Clarke Thu, 07/03/2008 - 08:20
When you do open the case, include the information I already mentioned in this thread. It will help narrow down where the problem lies.
The TAC engineer had me flush the jsp cache which seemed to fix the problem for a little while, although it's hard to say since simply restarting the services also fixed the problem for a little while.
Today i'm having the problem yet again. Other than reopening the TAC case, do you have any other suggestions i can test while the services are online and RME is having problems?
This problem is occurring again. Here are a list of the RME pages not coming up:
RME > Home
RME > Devices > Device Management
RME > Config Mgmt > Archive Mgmt
RME > Config Mgmt > Config Editor > Private Configs
RME > Config Mgmt > Config Editor > Public Configs
RME > Config Mgmt > NetConfig > User-defined Tasks
RME > Config Mgmt > NetConfig > Assigning Tasks
RME > Tools > NetShow > Command Sets
RME > Tools > NetShow > Assigning Command Sets
RME > Admin > ChangeAudit > Config Change Filter
RME > Admin > Config Mgmt > Exclude Commands
RME > Admin > Device Mgmt > Device Management Settings
RME > Admin > Device Mgmt > Device Credential Verification Settings
RME > Admin > System Preferences > RME Device Attributes
RME > Admin > System Preferences > RME Secondary Credentials
Any thoughts?
