Backup fail on 5.0(1)SR02_Build026
Jun 30th, 2008
I'm receiving the following error when attempting to backup Contact Center server:
Unable to perform Backup, please check the logs for more details.
Problem is, I'm not sure what log file this message applies to. I'm backing up to a windows file share on a separate server by way of \\servername\share$ UNC. I'm able to manually browse to the share with no issues and I'm not out of disk space so I'm not sure why this is failing. Hopefully, the log will clear this up once I find it.
Thanx in advance for any help.
LD
Overall Rating: 4 (1 ratings)
g-georgiou Wed, 07/02/2008 - 07:20
I am having the same issue. I am running 5.0(2)SR01_Build053
This is the error i get:
ArchivingFailureEvent id=324, archiveId=CRS_1215011932629_, errorCode=ARCHIVE_CREATION_ERROR, statusMessage=tar failed with error code: 2, cmd: Tar.exe -c --atime-preserve -f "\\10.105.13.100\ccx\Backup07-02-08#18-19.tar" \\STI\\Backup, refer to the MCVD logfiles for more details
com.cisco.archive.impl.ArchiveFailureException: ArchivingFailureEvent id=324, archiveId=CRS_1215011932629_, errorCode=ARCHIVE_CREATION_ERROR, statusMessage=tar failed with error code: 2, cmd: Tar.exe -c --atime-preserve -f "\\10.105.13.100\ccx\Backup07-02-08#18-19.tar" \\STI\\Backup
at com.cisco.archive.impl.BackupArchiveImpl.waitForArchiveResult(BackupArchiveImpl.java:494)
at com.cisco.archive.impl.BackupArchiveImpl.processArchive(BackupArchiveImpl.java:412)
at com.cisco.archive.impl.ArchiveImpl$3.run(ArchiveImpl.java:382)
at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
at com.cisco.executor.impl.ThreadStubImpl$RequestImpl.run(ThreadStubImpl.java:563)
at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
Did you manage to resolve this and how?
./G
ckltd7401 Wed, 07/02/2008 - 14:47
G,
I looked at windows task mgr and saw that my pagefile was very large and mem usage was at 90+ percent. My issue resolved after taking the following steps:
- Searched all log repositories on CC server
- Found following error in Cisco001MADM13.log under C:\Program Files\wfavvid\log\MADM
EXCEPTION:java.net.SocketException: Software caused connection abort: socket write error
- Rebooted contact center server
- Received jtapi error upon logon
The Cisco JTAPI Client versions are inconsistent. Please go to Cisco JTAPI Resync in the Unified CM Telephony Subsystem to install the Cisco JTAPI Client.
- Went to menu options; Subsystem | Unified CM Telephony
- Clicked on Cisco JTAPI Resync; process completed
- Performed Backup Now successfully
- Scheduled backups are ran successfully
Not sure if any of that will help your issue but I'll root around to see if I can find anything out for you.
Thanks a bunch for the reply,
ck
g-georgiou Thu, 07/03/2008 - 11:29
I resolved the issue myself. It had to do with access rights on the backup share. now everything works ok. The error message though could be more enlightening :).
Anyways, thanks for the help
