CiscoView Cannot Find Package for 6509 IOS
Jun 30th, 2008
When I try to run CiscoView on my 6509 I get the following error msg:
Cannot find applicable device package for
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component."
Believe it happened after I applied the "Dec 07" updates. THe following applies.
LMS 3.0.1
CV 6.1.7
Cat6000 v9.1
Cat6000IOS v30
IOS 12.2(17d) Sup 720
I tried deleting and manually re-adding in in CS with the IOS SysObjectID, but no change.
Any suggestions.
Joe Clarke Mon, 06/30/2008 - 16:03
What version of the Cat6000IOS CiscoView package do you have loaded? You can find this information under Common Services > Software Center > Device Update. Click on the CiscoView link.
