CCM integration with multiple domains?
Jun 30th, 2008
I just did a CCM 6.1 integration with AD. Super easy.
Now, can you integrate CCM 6.1 with multiple domains in AD? I'm not an AD guru, so I don't know all the terminology. However, the AD is set up so that there is trust between the Domains.
We also have UCCX 5.0 that we would integrate with AD.
Has anyone done this? Possible?
Thanks!
Erin
tzunt Tue, 07/01/2008 - 18:38
One limitation to be aware of is that we can only create 5 LDAP Directory objects in CUCM 5.1. I believe this may also be a limitation in CUCM 6.1 according to this bug CSCsg96397.
Here is the link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsg96397
I had not seen this limitation described in any of the documentation. Wish I knew this before trying to integrate to an AD environment with 10 OUs.
