spamtowho stats
Jun 30th, 2008
i love this little util, but it looks as if the weekly stats from my ironport device and the util itself don't gel. weekly we may block about 900,000 emails mostly due to poor reputation, but when i load in a weeks worth of mail logs and run spamtowho, i only show about 1/3 of that. can anyone possibly clue me in as to what i may be doing wrong here? thanks!
Tommy Foucha Mon, 06/30/2008 - 18:25
are you logging dropped connections, by default and for performance reasons those are not typically logged.
killerboots_ironport Mon, 06/30/2008 - 19:05
when i look in a log file i can see drops due to HAT, and DHAP etc. so i'd say it's logging them. my mail_log level is at Informational.
Tommy Foucha Tue, 07/01/2008 - 13:57
Not sure you would want to log every single dropped connection via SBRS but if you want to for tracking purposes go to Security Services/Message Tracking and edit the settings and enable "Save tracking information for rejected connections"
killerboots_ironport Tue, 07/01/2008 - 14:17
good point, yeah i don't really want to tax the system by having it keep up with that much logging. i'm a little curious what good the spamtowho app is though? if you don't have an accurate number of all connections, dropped and otherwise then i would think it throws off the stats for everything else.
