Routing issue 871
Jun 30th, 2008
I am trying to host a wbesite on a Linux server that sits behind an 871w router. When I try to telnet to the public ip port 80 I get "Could not open connection to the host on port 80" Do I need to add a NAT route or modify the ACL? My config is attached.
Thank you,
trippi Mon, 06/30/2008 - 18:20
You will need a NAT statement, what's your public and private IP for your Linux server? You can post a fake public.
jseneca64 Mon, 06/30/2008 - 19:43
Public (fake)
linux server:
Thanks for your reply...
trippi Tue, 07/01/2008 - 06:50
Static NAT rule.
static (inside,outside) netmask
ACL (not sure if needed, since you already have internal ACL)
permit tcp any host eq www
