Can I NAT prior to VPN Tunnel?
Answered Question
Jun 30th, 2008
I would like to add servers to a site to site ipsec tunnel configuration for transport.
However, I will need to NAT those machines for presentation at the other side.
For a Cisco 1760 (vpn endpoint) running on 12.3 code, is this possible?
If it is possible, could I get a link to a config? Or perhaps a snippet here?
We are using two ethernet interfaces for this:
ethernet1/0 is the inside
ethernet0/0 is the outside
Can't seem to find any documentation for it.
Paul
Correct Answer by Farrukh Haroon about 9 years 3 weeks ago
This is the 'NAT Order of Operation' employed by Cisco devices, It seems NAT is before the crypto check anyway
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
Farrukh
Overall Rating: 3 (1 ratings)
