Reg:asa5520
Answered Question
Jun 30th, 2008
Dear sir,
We have cisco asa5520 firewall and we have two different isp links now we want to maintain two different networks through this firewall(we want to use two separate gateways through this )Is it possible to do like this.Some body has told me to to do like that firewall has been on multicast mode .So how can i do that ,Any document plz.
Thanks&Regards
srini
Correct Answer by dhananjoy chowdhury about 8 years 12 months ago
Hi Srini,
Do you want to have One single FW connecting to the 2ISP's or you need Two FW's (context mode) ?
You need to check your requirements because there are some restrictions when you configure the ASA FW in multiple context mode.
Services like VPN, dynamic routing protocols etc won't work.
You can also check this sample configuration on Cisco site for Multiple ISP configuration.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
Correct Answer by Farrukh Haroon about 8 years 12 months ago
It is called 'multiple context' mode. Here is a sample config:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml
Please rate helpful posts.
Farrukh
Overall Rating: 5 (2 ratings)
Correct Answer
dhananjoy chowdhury Tue, 07/01/2008 - 00:56
  • Silver, 250 points or more
Hi Srini,
