How is "pri" calculated automatically by GLBP ?
Jun 30th, 2008
Hello.
By using "debug glbp events" can see something like the following
output.
GLBP: Fa0/0 123.1 Listen: k/Hello rcvd from lower pri Active router (135/211.102.108.161)
or
GLBP: Fa0/0 123.1 Active: i/Hello rcvd from higher pri Active router (167/211.102.108.152)
Note the (xyz / ip_addr)
Is the "xyz" prior to "ip_addr" the priority of the virtual forwarder?
I wonder how this number "xyz" be calculated by router.
Who knows, please?
Thank you.
ashok_boin Tue, 07/01/2008 - 02:50
  • Bronze, 100 points or more
It's not the priority of GLBP which we configured.
I am not sure about 135 or 167 here but what I observed in the labs is...
It says "167" when Primary VF is active & says "135" when Primary VG is inactive.
Pls find the following link which may help...
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6550/prod_presentation0900aecd801790a3_ps6600_Products_Presentation.html
Regards...
-Ashok.
Pravin Phadte Tue, 07/01/2008 - 02:55
  • Silver, 250 points or more
hi,
xyz is calculated in Weighted Load Balancing Algorithm.
It can be as simple as adding all the weight defined and the sum total will be the xyz.
regards,
pravin
ashok_boin Tue, 07/01/2008 - 06:29
Pravin,
I don't think this could be sum of all weights as per debugs.
Pls find the conf & debugs here.
PE-1#sh run | in glbp
glbp 1 ip 20.1.1.10
glbp 1 priority 200
glbp 1 weighting 200
glbp 1 load-balancing weighted
PE-1#debug glbp packets
GLBP Packets debugging is on
PE-1#un all
*Mar 1 00:04:58.831: GLBP: Fa0/0 Grp 1 Hello out VG Active pri 200 vIP 20.1.1
.10 hello 3000, hold 10000 VF 1 Active pri 167 vMAC 0007.b400.0101
*Mar 1 00:04:59.811: GLBP: Fa0/0 Grp 1 Hello in VG Standby pri 50 vIP 20.1.1.
10 hello 3000, hold 10000 VF 2 Active pri 167 vMAC 0007.b400.0102
All possible debugging has been turned off
PE-1#
PE-2#sh run | in glbp
*Mar 1 00:23:43.679: %SYS-5-CONFIG_I: Configured from console by console
glbp 1 ip 20.1.1.10
glbp 1 priority 50
glbp 1 weighting 150
PE-2#
*Mar 1 00:04:26.279: GLBP: Fa0/0 Grp 1 Hello in VG Active pri 200 vIP 20.1
*Mar 1 00:04:27.115: GLBP: Fa0/0 Grp 1 Hello out VG Standby pri 50 vIP 20.1.
Irrespective of weight configuration, it's giving 167 as Pri.
Regards...
-Ashok.
Pravin Phadte Tue, 07/01/2008 - 07:55
Hi Ashok,
I meant to say that weight algorithm is been used by cisco. This does not have any rfc to prove and calculate.
Weighted allows for GLBP to place a weight on each device when calculating the amount of load sharing. For example, if there are two routers in the group, and router A has twice the forwarding capacity of router B, the weighting value should be configured to be double the amount of router B. To assign a weighting value, the glbp x weighting y, where x is the GLBP group number, and y is the weighting value, a number from 1 to 254.
It would be great if some one can come up with and answer
