dhananjoy chowdhury Tue, 07/01/2008 - 02:03
  • Silver, 250 points or more
this can be done with the "archive" command which is there in IOS 12.4.
You can configure each device on your network to upload the running-config at regular intervals to a TFTP/ FTP/ SCP server.
And each host will upload the files on the server with a Unique file name.
Commands as below :-
Router1(config)#archive
Router1(config-archive)#path tftp://
Router1(config-archive)#time-period 10
The above commands will upload the running config of the Router1 at regualar intervals of 10mins to the TFTP server.
For using a FTP server in place of TFTP give the path command as
Router1(config-archive)#path tftp://:@
Rate if it helps
dhananjoy
Pravin Phadte Tue, 07/01/2008 - 02:08
Massimiliano is right and the link can help more. below is how the config will look like.
Router(config)# kron policy-list backuptest
Router(config-kron-policy)# cli copy running-config tftp:10.1.1.1 (may need some changes)
Router(config-kron-policy)# exit
Router(config)# kron occurrence backup at 22:00 Mon recurring
Router(config-kron-occurrence)# policy-list backuptest
Hope this helps.
Pravin
