07-01-2008 12:16 AM - edited 03-15-2019 11:39 AM
Good afternoon. There was a problem of the following plan: At installation CUCM 6.0 " the corporate catalogue " and services on all phones 7940, 7960 does not work. On CUCM 6.0 services for each phone are registered, but phone answers, that " the host is not found " and the same message stands out at viewing " the corporate catalogue ". And on IP Communicator all works (and " the corporate catalogue " and services). The fresh insertion of phone has not helped. Prompt as well as where to correct. Thanks.
07-01-2008 01:20 AM
For IP phone services, the "Host not found" error usually comes when name is used instead of IP address or unreachability.
Please find the following links which may help...
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009463f.shtml
Regards...
-Ashok.
07-01-2008 02:06 AM
Thanks. Works!!!
07-01-2008 02:14 AM
Bden,
ALways remember to rate post that are helpful especially one that resolves your issues. It encourages the person who helped you and it also provide good reference for others who emay experience similar issue as you did
