CLI on CME
Jul 1st, 2008
I have a problem sending out my number when calling out via PSTN. How do I enable or configure CLI so that my main number will be displayed on the receiver's phone?
Your input will be highly appreciated.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 07/01/2008 - 00:50
  • Hall of Fame,
    Founding Member
Hi, there is more than one way.
The simpler one, under isdn interface, configure "isdn calling-number XXX".
Please rate post if it helps!
paolo bevilacqua Tue, 07/01/2008 - 02:44
  • Hall of Fame,
    Founding Member
Do "debug isdn q931" with "term mon" and check calling number as wll plan/type.
emmanuel.shoroma Tue, 07/01/2008 - 04:35
I can see it from the debug messages.
Jul 1 12:32:33.415: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x6CC0
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '0126851300'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0112089153'
paolo bevilacqua Tue, 07/01/2008 - 04:40
  • Hall of Fame,
    Founding Member
Is 0126851300 your main number ?
If yes, ask telco if they want a plan/type set differently than ISDN/Unknown, as it is now.
If no, configure "isdn calling-number" with the right number.
paolo bevilacqua Tue, 07/01/2008 - 09:07
  • Hall of Fame,
    Founding Member
No problem, please remember to rate useful posts!
