07-01-2008 12:53 AM - edited 03-18-2019 09:13 PM
hi Dear,
I tried to install the unified presence 6.0 on the publisher but noway...
Shoul i need to install the unified presence on different server?
please help me.
Solved! Go to Solution.
07-01-2008 03:20 AM
linux appliances other than the CUCM BE are no co-resident, you need a server per appliance.
so, yes you need another server
javalenc
if this helps, please rate
07-01-2008 03:20 AM
javalenc
07-01-2008 05:06 AM
Hi dear,
Thanks for your helpful response.
Cheers
07-01-2008 06:59 AM
If this is test enviroment, you could get away with running vmware machines for CUCM and CUPS. So, you can do testing . I have them on my laptop and use softphone for testing. Also, integerated with OCS2007.
Cool stuff.
Cheers
Shahid
07-01-2008 07:02 AM
It's a about a new installation for a client
