Voice Gateway: Call Disconnecting
Jul 1st, 2008
Hi Friends
I have an issue with our voice gateway.
The issue is some of the incomming calls are getting disconnected. Here we are having 12 line fxo. and the gateway is using sip protocol. It is connected to cosmocom server.
Kindly give me a solution for the problem..
Jaime Valencia Tue, 07/01/2008 - 03:13
CME? CUCM? version?
a debug?
does it work for outbound?
sh run?
just saying that calls are disconnected does not provide info for a solution
if this helps, please rate
thejas.ramadas Tue, 07/01/2008 - 03:17
we r not using cme or ccm.
here is a defferent set up we r using cosmocom server. that is implemented by defferent person. it is a call centere application and is using sip
Jaime Valencia Tue, 07/01/2008 - 03:30
k, anyway we would need a sh run, call flow and debug to tell you what's going on
Paolo Bevilacqua Tue, 07/01/2008 - 03:34
Enable "debug ccsip message" and "debug vpm signal" with "term mon". That should reveal who is disconnecting the call.
Paolo Bevilacqua Wed, 07/02/2008 - 00:02
Hi, please enable both debugs for a same call and describe how it got disconnected exactly.
