Unattend Installation CDA / CAD / CSD - IPCC Express
Jul 1st, 2008
does anyone know how to create a MSI-Package for unattend installations of the client tools from IPCC Express? Or what paramaters to use with InstallDriver.exe?
Thanks in advantage,
Simon
ebreniz Mon, 07/07/2008 - 10:01
  • Silver, 250 points or more
Here's the procedure to try:
1. Be sure that you are logged into the agent PC as a local Administrator
2. From the browser, Save the install executable (InstallDriver.exe) to the
desktop
3. Using Winzip, extract the contents of that file to a new folder (like
C:\Temp\CAD).
4. Run InstallManager.exe from that new folder.
5. If the same error occurs, check for any IM*.dbg or IM*.log files in the
root of C:\ and send them to me.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a00801cf916.shtml
simonandorfi Mon, 07/07/2008 - 22:57
The question is:
"How to create a config file, or use parameters with that .exe to use SMS or something diffrent for installation?"
Simon
