VPN3030 SDI authentication problems
Jul 1st, 2008
I wonder if someone is able to help me with a problem I am having with a VPN3030 configured for remote access VPN and authentication via an RSA server.
A very brief run down of the problem is that when I am trying to test rsa authentication from a user configured group, the authentication fails saying that server is not found. If I try the same test from the base group the authentication then the RSA authentication works fine. The same thing happens when a remote dial vpn tries an attempt.
Any ideas would be appreciated.
hadbou Mon, 07/07/2008 - 09:53
  • Bronze, 100 points or more
In very rare situations, when connecting via HTTP or HTTPS (SSL) management session, LAN to LAN sessions and Remote Access Sessions are not displayed under Administration | Administer Sessions and/or Monitoring | Sessions. This appears to happen for sessions with SINGLE QUOTES (') in the name.Remove the SINGLE QUOTE (') from the site name.
