1841 Cisco router Question
Jul 1st, 2008
  • Gold, 750 points or more
the datasheet for the 1841 cisco router is saying that voice is not supported, only data is supported but the VWIC cards are available for thr 1841 router!!.
I need to run both voice, data and video on the 1841 using the VWIC2-1MFT-T1/E1. is that ok?
Collin Clark Tue, 07/01/2008 - 06:19
  • Purple, 4500 points or more
By voice they mean you can not run voice services like CCME. You can have voice traffic crossing the VWIC2-1MFT-T1 because it's just data. The router can not terminate a PRI, provide call signaling, etc.
Hope that helps
