cisco 2821 Support Dynamic DNS (DDNS) ???
Answered Question
Jul 1st, 2008
I am having Cisco router 2821 with WIC-1ADSL Inetrface card. I would like to know that router or router' support Dynamic DNS, which need to configure for dyndns.com site to established VPN connectivity
Correct Answer by andrew.butterworth about 8 years 11 months ago
I have uploaded another attachment to this post which should make is clearer hopefully?
You need to change the USERNAME:PASSWORD for your own DynDNS Username & Password and also change the interface line 'ip ddns update hostname MYHOSTNAME.homedns.org' to be your own DynDNS hostname - it might not have the 'homedns.org' suffix as DynDNS host others as well - check your account.
Andy
Overall Rating: 5 (1 ratings)
Wilson Samuel Tue, 07/01/2008 - 06:04
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hi Manoj,
Assuming your router is getting DHCP IP Address (hence the need for DDNS), one question arises how are you gonna complete the request/tracking to the dydns.com?
With PCs one can install their client and everything else is taken care of, however with Router, I'm not sure if it (client) will still work even if you tried to deploy NAT.
Best would be to try it out yourself.
Wilson Samuel
scottmac Tue, 07/01/2008 - 06:25
  • Green, 3000 points or more
If you use the SDM for configuration, there are some options for DDNS with several dynamic name registrars, including DynDNS.
I don't think they are compatible with DynDNS though, it never worked for me. I have a paid account with DynDNS
I'm running a 12.4 Advanced IP Services.
Perhaps it works for one of the other providers.
You can run a DynDNS client behind the router on any PC or server (server = "bad security idea")and get the correct address assignment, because NAT/PAT will make the client address the same as the router's outside address.
Good Luck
Scott
andrew.butterworth Tue, 07/01/2008 - 13:34
I spent a bit of time debugging DDNS with DynDNS & HTTP updates from the router and I now have it working perfectly. They have a policy were they don't like you updating if your IP address hasn't changed so you need to make sure the 28-day setting is in there or they suspend your account and send you a nice email...
This is my working configuration:
ip ddns update method DynDNS
HTTP
add [email protected]/nic/update?system=dyndns&hostname')">http://USERNAME:[email protected]/nic/update?system=dyndns&hostname=&myip=
remove http://USERNAME:[email protected]/nic/update?system=dyndns&hostname=&myip=
interval maximum 27 0 0 0
ip ddns update DynDNS host members.dyndns.org
By default the IOS CLI interprets the '?' and displays the available commands. You need to override this with v priot to entering the '?' character.
Andy
andrew.butterworth Tue, 07/01/2008 - 13:45
Apologies but I can't stop the forum interpretting some of the characters in the config script - it keeps posting wrong..
I have therefore attached it. The two final lines go under the interface, sorry I didn't include that bit in the file :o)
Andy
manojdubey02 Tue, 07/01/2008 - 20:38
Hi Andy,
Can u provide me some configuration document.
The above configuration can be done on global configuration mode on router.
I am not getting clear idea ... can explain me more ???
Correct Answer
andrew.butterworth Wed, 07/02/2008 - 01:06
Andy
