SDM availability
Jul 1st, 2008
The SDM is covered on the ICND1 and the CCNA exams. The prep books (Cisco Press and Todd Lammle's Study Guide) recommend downloading and becoming familiar with the SDM. They both say it is freely available from http://www.cisco.com/go/sdm, however when I go there to download it it says there is no software available ("There are no files of this type."). Has this been changed to require a support contract?
Thanks.
Overall Rating: 4 (2 ratings)
solpandor Wed, 07/02/2008 - 01:02
hi,
yes you do need a support contract to download SDM.
royalblues Thu, 07/03/2008 - 22:05
  • Green, 3000 points or more
i think the passowrd needs to be your email address
Narayan
career2007 Fri, 07/04/2008 - 08:47
thanks for the reply i had tried
anonymous = username
password = password
password = my email address associated with my profile
my user access level is guest access level I wonder how much this comes into play..
do you know of link of someone type of customer relations/tech support person I can IM to resolve?
career2007 Fri, 07/04/2008 - 08:53
ok i solved it the authentication banner gives bad info tells me to write anonymous and password as email...i typed in my my user name and password that i use to access this forum totally diffrent than anonymous and email it allowed me to download..thanks for your help all..
srivkind Fri, 07/11/2008 - 10:34
No you do not need an account.
You can download SDM ver 2.3.2 for free. Read the instructions for downloading. I think you can put in your email address as a password and log on with guest.
The demo only uses 2.3.2 though.
career2007 Sun, 07/13/2008 - 19:21
i installed 2.3.2 and down loaded the demo that is supposed to run on xp os how did you after copying data file to c\ directory how did you get the demo to run, typing in 127.0.0.1 is insufficient, 2.3.2 but i couldn't find executable file to install the demo..thanks
