AD Credential Passthru
Hello All,
I had this working once before, but seems the check mark escaped from it's box and I can't find that box.
I have an ASA 5520 running 8.0(3). I have SSL VPN licenses set up and have the SSL VPN working like a charm - except - When users attach to a web service on the network while attached via SSL VPN, they are prompted for their AD credentials, Again.
Users are attaching to the SSL VPN and are autenticated via RADIUS. RADIUS is tied to AD.
So, can anyone tell me, in the mass of GUI menus and sub menus, where I find the ability to enable cached credentials to be passed thru to a new credential request?
Thanks in Advance,
hadbou Mon, 07/07/2008 - 09:34
Secure Socket Layer (SSL) Virtual Private Network (VPN) technology allows you to connect securely from any location to an internal corporate network using one of these methods:
1)Clientless SSL VPN (WebVPN)
2)Thin-Client SSL VPN (Port Forwarding)
3)SSL VPN Client (Tunnel Mode)
