Find ports w/ more than x # of mac addresses
Joe Clarke Tue, 07/01/2008 - 08:46
There is a Campus Manager report which will show you ports with multiple MAC addresses. Go to Campus Manager > User Tracking > Reports > Report Generator > Duplicates. This will show you all ports which have at least two learned MAC addresses.
Joe Clarke Tue, 07/01/2008 - 18:53
No, the report is only for ports with MACs > 1. However, you can export this report to CSV, then run a post-export script to list the ports with more than five.
Joe Clarke Tue, 07/01/2008 - 19:01
For every port which has more than one learned MAC, the details for each MAC is listed in the report. For example, if switchA port Fa0/1 has three MACs, you will see three entries each having device name switchA and port Fa0/1.
This is not a best practice deviation, but a different report altogether.
jhussain00 Wed, 01/21/2009 - 13:11
Is there anyway to customize this report, or build a custom report so that it does the same thing with subtle changes. The reason I ask is because the report generated for me lists all the mac address per port, even if it is just a single mac. Is it possibly a bug?
