Mapping an outside address to an inside address
Jul 1st, 2008
Hi all,
im getting a problem mapping address on ASA.
I have a outside host (host-A) ( on same switch that outside ASA interface ( is plugged. And I have another host (host-B) on DMZ (
I wanna map the outside address to inside address
So, I changed the outside host ip address to (host-A) and put this command on ASA:
static (DMZ,WAN) netmask
but the packets to still go to the (host-A), not to host-B on DMZ. It seems ASA is not mapping the address properly.
What should I do?
dhananjoy chowdhury Tue, 07/01/2008 - 09:31
try the following commands on the ASA:
clear xlate
clear arp-cache
And also do a "clear arp" on the external switch.
Hope this helps.
Tauer Drumond Tue, 07/01/2008 - 10:19
I put this command and its still not working.
The ASA doesn't receive the packets.
