IP Phones often reboot
Jul 1st, 2008
I installed a Unified Com solution based on a CCM 4.1(3) with a Vgw 2081 mgcp. initially this version of CCM did not support ip phones 7906 & 7911. I have patched this CCM to support these IP Phones. Everything is good apart that frequently some IP Phones (whatever the model 7906, 7911, 7970, 7961) reboots.
I have tried to fix this this issue by looking for the outcome of this patches but nothing...
Can you help,
ahochau_2 Tue, 07/01/2008 - 11:12
Are they rebooting or are they trying to re-register with call manager? I had users report the same behaviour as it turns out the phone was losing its connection to call manager due to QoS issues. The control packets were getting dropped and the phones would try to drop into SRST but as soon as they registered to the SRST router they would reset and re-register to CCM.
We were also using CCM 4.1(3)
dom.a Sun, 07/06/2008 - 07:25
In my case, there is no SRST in the network. And when some IP Phones are rebooting/re-register), the others ip phones cannot make a call anymore (for this period).
Rgds
Chris Deren Tue, 07/01/2008 - 11:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What firmeware file are the phones using?
If you did not have these issues before the ugrade and no changes were made to the netowrk I would suggest opening TAC case.
Chris
Jaime Valencia Tue, 07/01/2008 - 17:42
  • Cisco Employee,
  • Hall of Fame,
    2011
look at the application log for further details of the reason
javalenc
if this helps, please rate
dom.a Sun, 07/06/2008 - 07:28
The upgrade was made just after installation of the CCM, so it is now difficult to know if this issue existed before.
No vlan voice was configured in this IPT network. Is this can caused this issue ?
regards
Justin Brenton Sun, 07/06/2008 - 13:04
  • Silver, 250 points or more
Hi dom_a,
Could you post your configurations without any public ip addresses listed?
Since your not using a voice vlan your not seperating your voice and data traffic. I would imagine your having issue's with priority of the voice traffic. You should have a voice vlan and a data vlan.
Do you have QOS enabled on the network?
What firmware version are you using for the phones?
HTH, Please rate below if so!!
Justin
dom.a Tue, 07/08/2008 - 03:19
do you mean CCM configuration ? if yes how to collect it ?
No QoS enabled on the network.
