MGC rtrv commands
Jul 1st, 2008
Hello people,
I am having a problem with retrieve commands in the MGC.
After install a new license in my PGW I've created an EISUP link towards HSI.
When I make some commands in the MGC I receive an error as you can see attached:
"Command aborted".
My question is...is this maybe a problem with some features of the license, or, this is a problem with the MGC it self?
With regards and thanks.
Overall Rating: 1 (1 ratings)
Urban_Nights Mon, 07/07/2008 - 09:43
Thank you for your reply.
I found out today with Cisco that the problem was with the MGC license...so, the problem is solved by patch.
Thank you anyway.
Regards.
