Change IP address for Agents for IPCC
Jul 1st, 2008
I need to change the IP address for all the current agents to point it to new IPCC server.
I am not sure how to do that. Can someone let me know how can that be done.
k_vishwesh Tue, 07/01/2008 - 10:56
hi Rohan,
You need to do the follwoing:
1) if you are using IP Phone service , then you need to modify the ip address on the CCM IP Phone service.
2) If you are using CAD , then uninstall and install the agent application, while you do installation it will pormpt for the IP addess and enter new ipcc server IP.
I hope it is clear.
