VT Advantage: Video Calls over Wan to different Cluster
Answered Question
Jul 1st, 2008
I want to know if its possible to make a Video call (VT advantage) to another callmanager cluster with VT advantage...
This is the scenario..
CCM6.1.1 with Vt advantage>>>IP WAN>>>CUCMBE with VT advantage.
Can this work?
If so what configs do I need to enable on the Voice gateway..
NB: Video calls work ok internally in both clusters
Correct Answer by jleon22 about 8 years 3 months ago
You should be able to configure an intercluster trunk between the 2 systems that will send calls over the wan, which will allow you to make video calls. Also, be aware of your bandwidth usage. CAC is recommended.
Overall Rating: 5 (1 ratings)
