L2TPv3 - one-way tunnel?
Jul 1st, 2008
I've got an L2TPv3 tunnel set up between our central location and one of our remote sites. Everything looks OK, but data is only flowing one way (from the central side to the remote side, it looks like). Has anyone seen anything like this?
Thanks!
coolprinki Thu, 07/03/2008 - 23:25
Hi there, can you please check if the gateway on the remote location is set to the L2TP tunnel and not to any other interface. If there is no specific path set, then the default path needs to be checked.
Is dynamic routing enabled for the tunnel traffic flow??
