reintallation
snzeadibe
Can i reinstall the Call manger server with the CD as described(Unified Presence 6.0 Software - available with CCM)that came with the server
Jaime Valencia
it sounds to me that what you have is CUPS and not CUCM on that CD
javalenc
if this helps, please rate
java
gary.simpson
You should have received a DVD that has CUCM6, CUCM-BE & Unity Connections.
You use this DVD to rebuild the system.
Hope this helps,
Gary.
how do i receive it because it did not come wioth the server
you need to reach customer services or use the PUT to get the media
javalenc
java
