07-01-2008 01:26 PM - edited 03-11-2019 06:07 AM
I'm about to upgrade the CSC module on my ASA from 6.0 to 6.1. Will this cause the module itself to reboot, or the whole ASA?? If just the module, will email still go through (unfiltered)? or halt?
Thanks!
07-01-2008 06:07 PM
You have to reboot firewall intself.
NOT only module.
- Dharmesh Purohit
07-11-2008 09:28 PM
If you are re-imaging the CSC module, only the CSC module will reboot, the ASA will NOT reboot.
If you are upgrading using the PKG files, then the CSC will go down temporarily while the code/patches is loaded.
Your traffic should go through un-interrupted if you have your CSC set for 'fail-open' in the policy-map configuration of the asa (Hint: look at the output of 'show policy-map')
If it is set for fail-close, then traffic sent to the module may be interrupted until the CSC is back up and running.
