How to check remaining device RTU licenses in CM 4.1
Answered Question
Jul 1st, 2008
Is there a way to check remaining device RightToUse (RTU) licenses in CM 4.1.3?
I'm familiar with the License Manager feature in CUCM 5.1.3 and any similar functionality in ver 4.1.
Thanks!
Correct Answer by thisisshanky about 8 years 12 months ago
With CM 4.x you buy a license per phone type. If you have a 7825 it can officially support upto 1000 phones, 7835 - 2500 phones and so on...If you have 1000 phones (7940) then you should have bought from your Cisco Partner 1000 of the SW-CCM-UL-7940. So to answer your question, you can simply look at how many more devices u can expand to on ur current server based on how many devices you have right now.
Overall Rating: 4 (1 ratings)
Correct Answer
thisisshanky Tue, 07/01/2008 - 21:30
  • Purple, 4500 points or more
