Warning message
Rob Huffman Wed, 07/02/2008 - 09:53
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jian,
As SNR is a relationship between the client machine and the AP you need to use a product like Netstumbler to find these values;
Here is some more info to help get you started;
http://www.netstumbler.com/
Performing a Site Survey
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4555/products_installation_and_configuration_guide_chapter09186a0080184b69.html
Or this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4555/products_installation_and_configuration_guide_chapter09186a0080456a16.html
If you are using a Cisco card here is where to download the ACU (you need CCO Login)
http://www.cisco.com/cgi-bin/Software/SWSearch/SWSearch_results.cgi/SWSearch_results.cgi/SWSearch_results.cgi/SWSearch.txt?isChild=false&file_delimiter=contains&file_pattern=acu&list_format=html
Hope this helps!
Rob
dennischolmes Thu, 07/03/2008 - 05:00
  • Gold, 750 points or more
If you have controller based APs in the client section open the client page and then do a link test to the client. This will give you RSSI, SNR, and packets sent and received. If you are running a high level CCX client you will also get data rates sent and received.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
