configuration router ADSL
Answered Question
Jul 1st, 2008
My ISP will have me public subnet with 6 address that I'll configure on ethernet of my router ADSL ( 847 ).
Behind router I have to install ASA firewall with interface outside on the same ethernet of the router and on ASA I'll configure NAT and all other policy of security like VPN an so on.
Does anyone advice me about configuration
of the router?
Is there some document or example on web ?
best regards
Lorenzo
Correct Answer by Pravin Phadte about 8 years 7 months ago
Hey thas good to know.
best of luck.
Plz rate the post if helps
regards,
Pravin
Overall Rating: 5 (1 ratings)
lformelli Wed, 07/02/2008 - 04:48
Thank you,
but I know like configure ASA,
I need sample configuration of router.
best regards
Lorenzo
Correct Answer
Pravin Phadte Wed, 07/02/2008 - 05:29
best of luck.
regards,
Pravin
