Error message from switch ??
Jul 1st, 2008
Hi everyone,
I'm getting the Error message from switch WS-C2950G-24-EI
software ver 12.1(22)EA8
ERROR in strata_protected_notify:line987: can't get remote inst pointer
Any one know or have any ideas about this message?
Best regards
-Tor
owillins Tue, 07/08/2008 - 05:44
  • Silver, 250 points or more
It seems to be related to protected ports and port channels. Temporary solution is remove FEC config and reload the switch.
rabbani30 Tue, 07/08/2008 - 06:02
how do i identify which one is protected ports & port channels..?
cvindas Tue, 07/08/2008 - 10:17
that is a hardware issue, you need to replce the switch, if you have warranty or Smarnet, use it.
Regards.
