Direct Inward Dial VIC2-4FXO
Jul 2nd, 2008
Hi Guys,
Does anyone know if the vic2-4fxo card will support direct inward dial and if so do you have any documentation as i cant find any which confirm this....thanks...
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Wed, 07/02/2008 - 00:26
No, it does not support any form of DID and is not possible to do anything to make it support that.
If you are in North America the card to use is VIC2-xFXS-DID. No other cards can be used for analog DID.
Please rate post if it helps!
Steellllllllll0 Wed, 07/02/2008 - 00:32
Outgoing calls though wont be a problem is that correct ? Also, the site deployment is Asia therefore which card will i need to purchase to enable 8 analogue lines for DID/outgoing calls ?...thanks !!
Paolo Bevilacqua Wed, 07/02/2008 - 00:41
generally DID lines do not support outgoing calls at all. Please clarify with telco which exact types of lines you will be getting. Analog DID outside North America is rare or non-nonexistent, so double check.
The best thing would to be to get ISN BRI or PRI. This would give you DID, bi-dir lines and many many other advantages. Check if it is available.
As a recognition to those prividing answers, please rate usefl posts!
