Logging login attempts
Jul 2nd, 2008
Is there any way with ASA's to generate a syslog event for each time someone logs into the console either successfully or otherwise? We are using the local database and not TACACS/RADIUS
JORGE RODRIGUEZ Wed, 07/02/2008 - 11:17
With logging asdm informational statement you should be able to see in real time in asdm logs any connections to the firewall including console enable, ssh, or even telnet access to the firewall, the informational would also output fail loggin attemps by the username.
