Fraser Reid Tue, 07/08/2008 - 06:56
It depends on how L3 intensive it should be - an 1841 Router should do for something like basic internet traffic and a little WAN stuff
if you want a little more the nI would start with a 2801.
AS far as switrches are concerned it also depends in internal infrastructure ( lots of users can use 1 stack of switches (3750) or users are in groups of up to 48 (2960/3560) depending on you also needing L3 capability or not and on the 3750 a Stackable Switch system....
Please rate if helps
Fraser
