::: VSPT :::
Answered Question
Jul 2nd, 2008
Hi people,
when I am trying to connect to a MGC via VSPT I receive an error.
It seems that the connection is refused.
Can you please help me with the attachs?
Regards and thanks.
Correct Answer by irisrios about 8 years 9 months ago
VSPT Release 2.2 is designed to be used with Cisco MGC software Release 9.2. If you are using an earlier release of the MGC software, you must use VSPT Release 1.6 or 2.1. VSPT Release 2.1 is designed to be used with Cisco Media Gateway Controller Software Release 9. If you are using an earlier release of the MGC software, you must use VSPT Release 1.6.
http://www.cisco.com/en/US/docs/net_mgmt/vspt/2.2/vspt22ov.html
Overall Rating: 3 (2 ratings)
Correct Answer
irisrios Tue, 07/08/2008 - 10:45
  • Silver, 250 points or more
