about QoS
Jul 2nd, 2008
Hi folks,
I just have to check QoS configuration in my router as per one of the TAC guy required.
Experts can any body suggest me on this like what is the command to check QoS configuration, use of this.
Thanks in advance.
Naidu.
Pravin Phadte Wed, 07/02/2008 - 03:48
  • Silver, 250 points or more
Show Run
You need to check the running configuration on the device to see what kind of qos is been configuerd on it.
Pravin
ilnaiduccna Wed, 07/02/2008 - 04:31
Hi Pravin,
Thanks for the early reply.
As you told what fields shall i see exactly to find what kind of qos.
Naidu.
Pravin Phadte Wed, 07/02/2008 - 04:50
few this i can list is.
Class map, Policy map, Rate-limit, traffic-shapeing, DSCP .
If you can paste the configs i can point out qos configs.
regards,
pravin
