07-02-2008 05:14 AM - edited 03-05-2019 11:57 PM
Hi All
Just going through some BCMSN study material which covered the redundancy protocols HSRP & VRRP, the redundancy/load balancing protocol GLBP and the Server Load Balancing protocol SLB.
I appear to have HSRP, VRRP and GLBP available on the routers in my home lab (2500's, 2600's & 3600's) but I don't appear to have SLB even though I am running IOS 12.4 on most of the routers. I do however have SLB available on a 7206VXR router running IOS 12.3 code.
I am therefore wondering what hardware or software is required to configure SLB on the routers.
I have not yet checked whether SLB is availabel on my L3 switches (3550's and 3750's).
Any advice/help you can provide would eb much appreciated.
Best Regards,
Michael
Solved! Go to Solution.
07-02-2008 05:23 AM
If you use the feature navigator and search by feature, server load balancing,
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
From the results, if you have a look in the platforms box, you will see that the lowest end router with this feature is the 3640.
Therefore, you need to have this minimum hardware to get the feature.
You can use the FN to find the ver that you require for your 3600, since you done specify which model you have.
Cheers,
LR
07-02-2008 05:49 AM
07-02-2008 05:23 AM
Cheers,
LR
07-02-2008 05:49 AM
In 12.3 code, I guess it is supported in 3600/3700.
HTH,
Nagendra
07-02-2008 06:40 AM
Hi Guys
Cheers for the response and helpful information.
I have 3620's and 3640's in my lab and neither seem to have SLB support. However this appears to be due to the fact that the version of IOS 12.4 they are running is too low.
I need the MD release 12.4(19b) or the LD release 12.4(13) and I have 12.4(5a).
At least now I know why :) Cheers.
I can always use Dynamips to get some hands on practice with SLB configuration as I have some 7206VXR images which support this feature.
Best Regards & Thanks again,
Michael
