Stored procedure
Jul 2nd, 2008
Is it possible to make an ODBC connection to a mysql database using a stored procedure ?
darpotter Wed, 07/02/2008 - 06:55
Could be..
I assume you mean for ODBC authentication? Only works for software ACS and not appliance.
There is a cisco white paper (I wrote) that says all about ODBC auth - might have been merged into main ACS docs.
lni1 Thu, 07/03/2008 - 01:03
I configured everything following the white paper, now it keeps saying "External DB [ODBCAuthDll.dll]: DSN 'CsntOdbcAuth' doest not support procedures". I executed the stored procedure and it works, where is the problem?
darpotter Fri, 07/04/2008 - 03:15
As I recall ACS uses the Windows SQLGetInfo(SQL_PROCEDURES) api to ask the database if it supports stored procedures.
Your database must be returning something other than "Y"
You could ask your database providers tech support for their comment.
