how to enable another segment
Jul 2nd, 2008
I config the 1811 to be a FW. It can filter and block IM service if the PC and workstation are on the VLAN1. It is working properly.
R1
interface VLAN1
ip address 192.168.12.1 255.255.255.0
I will put another router and connect to 192.168.12.0 segment.
R2
Interface FE0/0
ip address 192.168.12.2 255.255.255.0
Interface FE0/1
ip address 192.168.18.2 255.255.255.0
Interface FE0/2
ip address 192.168.19.2 255.255.255.0
I find that all packets of R2 (192.168.18.0/24 and 192.168.19.0/24) are blocked by 1811.
How to configurate the 1811 so that the 1811 can allow those segment go out and protect those two segments?
rdgs
a.alekseev Wed, 07/02/2008 - 06:25
  • Gold, 750 points or more
run some routing protocol (ospf, eigrp) or use static routes.
on r1
ip route 192.168.18.0 255.255.254.0 192.168.12.2
on r2 i think
ip route 0.0.0.0 0.0.0.0 192.168.12.1
anitachoi3 Wed, 07/02/2008 - 07:04
the routing had been configured.
If I disable the firewall, the packets can access out side.
R1
interface Vlan1
no ip inspect sdm_ins_in_152 in
If I enable fw again, two segment packets are blocked in 1811. any idea?
rdgs
