MS Active Directory module in LMS 3.0
Jul 2nd, 2008
  • Silver, 250 points or more
I want authentication of LMS 3.0 via my Active directory Server. As per LMS 3.0 installation guide, I did but not successfull. I also not found enough material on this topic. Will I integrate it through Cisco ACS?
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 07/02/2008 - 08:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you can use the TACACS+ module to authentication to an ACS server which is using an AD database on the backend.
ahmedshoaib Thu, 07/03/2008 - 02:50
Thanks Clarke, what about if I used Non-ACS MS Active directory module of LMS 3.0? I try to use but it not function properly.
Joe Clarke Thu, 07/03/2008 - 08:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What error do you get using it? How have you configured it?
ahmedshoaib Fri, 07/04/2008 - 04:00
Dear Clark; please find the configuration I did on LMS common services;
Authentication - Non-ACS (MS Active Directory)
Server: ldap://ldap.companyname.com
userroot: cn=%user%, dc=servername, dc=companyname, dc=com.
prefix: cn=
login fallback option= true (only for Admin user)
I still not authenticate LMS through active directory. LMS give me access via fallback option (meand via admin user).
