CM6 Upgrade
Jul 2nd, 2008
I am just about to upgrade from 5.1 to 6.1, is there any major issues I should be aware of or is it a simple in-active partition upgrade?
The customer is currently using attendant console on version 5 does it change much on version 6? I take it I need to re-install the SW
Overall Rating: 5 (1 ratings)
thisisshanky Wed, 07/02/2008 - 07:04
  • Purple, 4500 points or more
AC doesnt change a lot in version 6. you will need to resinstall AC. Its a good idea to save speed dials and such on older version before reinstalling to newer version
Also read these threads
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf3cc2
