debug to detect MAC in port of the Switch
Jul 2nd, 2008
Hello I need a debug that shows which MAC they are have beeb learning for the port of switch 3750 or I need to see in logging what MAC exists in each port of the switch.
Something como sh mac-a static but I require this be dynamic and sent a console o debug.
can you help me?
Collin Clark Wed, 07/02/2008 - 07:48
You don't need a debug, you can use the following command(s)
show mac-address interface fastethernet0/1
If you know the IP address and want to find the MAC and which port it's plugged into-
show mac-address address [mac address]
Hope that helps
zztopping Wed, 07/02/2008 - 08:23
or show mac-address dynamic to show all learned MACs on all ports in a table
Giuseppe Larosa Wed, 07/02/2008 - 12:07
Hello Collin,
you do sh ip arp on default gateway for that address
then on switch
sh mac-address address
if you have multiple switches you start from the core switch(es), find out the interface where the mac address has been learned and with sh cdp n you find the access layer switch
then you go in telnet/ssh to the access-layer switch repeat the command sh mac-address address and you find the port where the device is connected to.
Of course, you have just forgotten to list the sh ip arp (mistyping) but it was in your thoughts
hope to help
