SRST & VoiceMail
Jul 2nd, 2008
have voicemail XXXX in call-manager fallback. When in SRST, gets fast busy when hit messages button. Also cannot dial internal 4 digit extensions, which I suspect is related. Any help is appreciated.
Overall Rating: 3 (1 ratings)
Jaime Valencia Wed, 07/02/2008 - 09:58
please post the whole config, is the VM going to be reached thru PSTN or is it local?
javalenc
if this helps, please rate
balitewiczp Wed, 07/02/2008 - 11:26
VoiceMail is local. Here is the dial-peer and call-manager-fallback.
dial-peer voice 1 pots
description Outbound SRST LD
destination-pattern 91..........
port 2/0:23
prefix 1
dial-peer voice 3 pots
description Outbound SRST Intl
destination-pattern 9011............
port 2/0:23
prefix 011
dial-peer voice 6020 voip
session target ipv4:172.19.64.130
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4 pots
description Outbound 10 Digit Local
destination-pattern 9[2-9].........
port 2/1:23
dial-peer voice 5 pots
description Inbound
direct-inward-dial
port 2/1:23
dial-peer voice 6 pots
direct-inward-dial
port 2/0:23
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address X.X.X.X port 2000
max-ephones 200
max-dn 200 dual-line
system message primary phone system in Backup Mode
dialplan-pattern 1 3234366... extension-length 4 no-reg
dialplan-pattern 2 3234366... extension-length 4 no-reg
voicemail 3000
call-forward busy 3000
call-forward noan 3000 timeout 4
time-zone 5
date-format dd-mm-yy
Jaime Valencia Wed, 07/02/2008 - 12:24
if the VM is local you need to configure CME and the VM ports to register locally, also the VM system to failover to the CME if primary fails
javalenc
