Enabling jumbo frames on WAN link
Jul 2nd, 2008
Should I expect any impact on applications after enabling jumbo frames? I have two sites connected over a 10Gb link terminated at 6509's on each site, an SRDF deployment requirement calls for the enabling of jumbo frames across the WAN and LAN on the path between the EMC devices, has anyone experienced any issues after enabling jumbo frames? Thanks in advance.
Giuseppe Larosa Wed, 07/02/2008 - 11:47
  • Hall of Fame,
    Founding Member
enabling the jumbo frames makes the switch to change the organization of hardware interface buffers that will be shorter.(in number of frames that can be handled)
If you have to transport Fiber Channel over IP (TCP actually) this provides you the benefit to be able to carry fiber channel frames inside a TCP segment without fragmentation.
hope to help
Giuseppe
