AS5350 as an XOT pad
Jul 2nd, 2008
Is it possible to configure an AS5350xm to behave as an X25 (XOT) pad? I dont seem to be able to find any info...?
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 07/02/2008 - 11:26
Do you have the device online ? Just type "pad" or "x3" to check if it is in the image you have.
Please rate post if it helps!
Almartin Wed, 07/02/2008 - 20:50
Just tried that and I get "incomplete command.... Sounds like bad news.
Paolo Bevilacqua Thu, 07/03/2008 - 01:23
Depending on what you've typed it can be normal. Read the manual to learn how these commands are used.
Almartin Thu, 07/03/2008 - 08:40
I have set things up as follows. I can now make an outgoing XOT call using the PAD command and that is ok. I can dialin to the PRI and the call is answered my a modem ok. What I am trying to acheive is linking the 2 together. Eventually the NUA called will either depend on the number dialled or be entered as the result of a prompt....
Paolo Bevilacqua Thu, 07/03/2008 - 08:46
That is perfectly possible. You use "autocommand ..." under line config. Using modem pools, you can make so that different called numbers go to different pools of lines that do different autocommands.
Almartin Thu, 07/03/2008 - 08:49
Thanks how can I link it to XOT that is where I seem to be losing it....
Almartin Mon, 07/07/2008 - 07:57
Things are progressing but I have reached another hurdle.
I have set things up using the autocommand and modemcap info under the line. Now I would like to vary these depending on the number dialled. I have searched for DNIS and there seems to be so many references to this. It is simple data, no voice. Is there a simple way to allocate these resources to a DNIS?
Almartin Mon, 07/07/2008 - 08:22
That looks promising, but it means tying lines up to specific roles. I would rather have all lines available to deal with modem or ISDN and the the criteria (autocommand, modem etc) dependant on the number called. Is it possible?
Almartin Mon, 07/07/2008 - 08:58
I am using modemcap at the moment but I am not sure that is what I will finally use.
That last doc was very interesting.... you are getting so near....
If you can imagine a group of 64 lines.
User 1 dials 1234 any modems answers at 2400 - makes a pad call to nua 2342123...
User 2 dials 2342 any modem answers at 9600 - makes a pad call to nua 2342567....
User 3 dials 3456 any line answers call as ISDN possibly V120 - makes a pad call to nua 2342789....
