VPN Concentrator 3020
Jul 2nd, 2008
I have the following especification:
CVPN3020E-NRBUN-K9 Concentrador VPN Model CVPN3020E with 3 ports FE, module SEP-E and power supply
CVPN3020-SW-41-K9 VPN3020:SW
In teory, equipament supports 750 IPSec Sessions , but only 30 clients connects in the vpn concentrator, what's happening? Configuration problem? Anyone limit problein in configuration?
Best regards,
JORGE RODRIGUEZ Wed, 07/02/2008 - 12:06
Eduardo, I would suggest to revise your configuration on the concentrator for RA , specially the address management pool assigment for your vpn clients whether is configure local or if you are using other internal dhcp .. I would start checking these, if this seems to be correct what other information do you see in the real time logs after you reach the 30th vpn client connections..
General VPN 3000 configuration examples
