vpersaud001 Wed, 07/02/2008 - 11:17
Thank you Mark. No modules in the router - just the 4 LAN ports. Because other people have access to my client's network equipment I need to restrict physical access to the ports.
I tried the port security command already and it's not recognized. The IOS version is 12.3(7)T1. Could it be an IOS issue?
Mark Yeates Wed, 07/02/2008 - 12:07
Unfortunately I am not seeing any documentation that shows that the router supports port security. I also looked at the feature navigator and didn't see it supported in the IOS either. If port security is a necessity I would recommend a catalyst switch to plug your users into.
Mark
